3 and 4 pin sys fan connection
hold
I've recently purchased a small 4 pin computer fan for my case. I didn't notice until I tried to install it, that my motherboard has only a 3 pin connection for the sys fan slot. My question is, is a 4 pin still good to use on the 3 pin? If it is, will it short, overheat or ruin my motherboard? Thanks for any help.
QueBert
22,983
1,179
the 4th pin's for PWM, the fan will work fine you just won't be able to monitor & adjust the speed.
artvscommerce
1,145
17
In my experience it depends on the fan. 3-pin fans are throttled by voltage and some PWM fans don't have a very wide range for operating voltage.
