At work we have a bunch of workstation with P4s at 3.4 GHz, and sometimes, System properties shows 2.78 GHz as the actual speed.
Restarting usually sets it back to 3.39, but sometimes it takes a shut down for a few minutes.
I just found one showing up as 2.37.
Would this be throttling or could it be something else like a low power state. Is there any way to tell without installing any software on these systems. Maybe a program to fun from a flash drive?
These are HP convertible mini-towers dc7700 series if that helps at all.
The inferior of the case looks clean, with a seemingly decent aftermarket cooler.
I want to move to conroes for more speed and less heat but that will take a while so until then I need to find out what is wrong with these systems.
Thanks
Thanks
