Originally posted by: RussianSensation
Originally posted by: Peter
That's because latency matters a lot. 3-4-4-8 at 250 MHz is slower in many applications than 2-2-2-5 at 200. "Slower", in what I said above, includes all aspects of slowness - both lower clock and higher latency.
Well now that you do realize that latency timings win over speed, it is pretty clear he will not suffer more than 2-3% performance degradation running at 333mhz using ratios, somewhat undermining the VERY dependency of a P4 on Ram speed that you speak of
With your fact twisting skills, you should be a politician.
Of course there is a quantification to everything, and of course, DDR500 at extremely slow timings is slower than DDR400 at absolutely maxed out timings. Saying generically that "timings win over speed" is laughable enough that I won't bother talk about it.
But you're distracted away from the point anyhow, completely so. No matter what kind of RAM performance delta we're talking about, P4 will be noticeably more affected from it than an Athlon-64. And that's the question here. Got anything to say about THIS?
Algere, not really. Socket-939 is just around the corner, and some socket-940 boards also accept non-registered RAM as long as you keep it to one DIMM per channel.
