Ok, going from my current AMD xp2100 @ 2.3 (211fsb) to a sl6wk P4 3.0 + the abit board and will use my pc3200 twinmos winbond.
Anyone have a similar setup? I believe the 3.0c is locked at 15 on the multiplier,so I will have to play with FSB. I am hoping to squeeze out 220 on my ram, but was never able to with my AMD setup (altho didn't play with dropping the multi enough).
Any opinions? I plan on using my current SLK-800 + TT smartfan 80mm.
Will be happy to get 3.5ghz out of this setup, altho I realize eventually I may have to step up to faster ram. I will basically be swapping out my NF2 board and AMD chip and replacing with the P4 setup, so you can see rest of stuff in my sig for the bigdawg rig.
Been an AMD man for a while as far as my Oc'ing goes, so any advice on this P4 setup is much appreciated.
