Hi,
I ordered 2x Rosewill Hyperborea 140mm fans and a Y splitter from Amazon, but I can't seem to find the power draw of the fans using google search.
I plan to connect both fans using the Y splitter to a single chassis fan controller on my Z170-PRO motherboard. I'm wondering if the two fans together will still be within the power limitation of that single controller?
Thanks in advance
Also, I'm wondering what does CPU_OPT do? My CPU fan is connected to the CPU_FAN slot, so what hypothetically, what will happen if I connect a chassis fan to the CPU_OPT slot? Will it be controlled together with the CPU_FAN?
Thanks in advance
 Facebook
Facebook Twitter
Twitter
