2x ati hd 6770 or gtx 560 ti?
jedazar
7
im looking at getting a whole new rig, and im just wondering whether dual 6770 or a single 560 ti is going to be better. which should i go for?
supremor
266
The only time time where you would want to go dual GPU's is when there is no single GPU to satisfy your performance needs or if you already have 1 card and getting another is significantly cheaper than buying a newer, better GPU.
There is no point in dual 6770's, you may as well get a 7850 or an Nvidia equivalent.
jedazar
7
i just found a deal online with dual 6770's, i was wondering whether it would b worth it
supremor
266
Well I cant really say without knowing where it is you shop. Find the best single card you can for the same price as those 6770's and tell us what it is so we can advise you better.
ShintaiDK
20,378
130
^^ This. Dualcards also gives alot of issues and problems.
Jun 19, 2004
24,135
1,592
I agree with supremor. That said, in most games, two 6770's would give greater performance than one 560 ti.
jedazar
7
thanks guys, had a look and added in some peripherals i need and realised its gonna end up 2 much, but thanks anyway
ASK THE COMMUNITY
