2TB WD passport USB drive and WinXP
Jul 17, 2011
125
Opinions/Advice/Solution needed.
I ordered a 2TB WD "Passport" backup drive for a computer running WinXP.
I must have still been under anesthesia thinking,
1) XP would recognize such a large hard drive,
AND . . .
2) that this 2TB passport would NOT come GPT formatted which XP also does not recognize.
At this point upgrading the PC to Win7 or Win 10 is not an option.
I need to backup all current data on the XP's 500GB drive as well as an already full WD500GB "MY Book" external hard drive.
I'm thinking I have to remove the GPT type format (if XP is going to recognize it) and most likely that will mean 4 separate logical 500GB NTFS partitions or no?
Can I leave this passport intact at 2TB and reformat it to NTFS or at least separate logical 1TB partitioned NTFS drives?
Any input will be highly appreciated
Thanks Chris
Shmee
8,275
3,162
To back up important data to the external, simply boot a live linux disc such as parted magic or ubuntu. It will recognize both drives, and then you can transfer data as needed.
