- Aug 25, 2001
- 56,587
- 10,225
- 126
http://www.servethehome.com/?p=231#more-231
" One thing I had forgotten is that WHS is built on Windows Server 2003 and can only utilize MBR partitions. While this is generally fine, the 11x 1.5TB drives - 2x for parity and -1x for a hotspare yielded 10.92TB of available storage (1.365TB x 8). Due to the MBR partition and WHS limitations one can have a maximum of 8TB in a raid array for WHS on a set of drives. This is because 2TB per MBR partition and 4 partitions per device. "
Is this true? I thought that the 2TB limit was a hard limit, in that you could only use 2TB of the physical drive for a partition, not that you could partition MULTIPLE 2TB partitions on a larger physical disk.
Can someone comment which is correct?
According to this:
http://en.wikipedia.org/wiki/Master_boot_record
"Both the partition length and partition start address are stored as 32-bit quantities. Because the block size is 512 bytes, this implies that neither the maximum size of a partition nor the maximum start address (both in bytes) can exceed 2^32 × 512 bytes, or 2 TiB."
That was my understanding, that any sectors above a 2TB limit were entirely off-limits to MBR partitions.
According to this:
