2TB HDD running slow.
MobiusPizza
2,001
To be honest Old Hippe 7MB/s is abnormal for sequential transfers on a modern HDD, even on a 5400rpm and 2.5" HDD. Op said he were copying 15GB split in 20 files, which is pretty sequential.
If he's talking about random 4k small file transfers, then 7MB/s is normal.
Old Hippie
6,361
That's exactly what I'm thinking.
He's making a copy of Windows and I figured he got to a buncha small files.
Edit.......
At first I was getting a sustained write of about 30 MB/sec but after 4-5 minutes it plummeted down to like 6 MB/sec. I have been unable to get my sustained writes that high again.
coder_t2
92
I posted that I was copying large files. I have also tried other groups of large files (1GB+). I am well aware that copying large amounts of small files will decrease overall copy rate. So I really wasn't trying to be insulting, but if you thought I meant that I was copying the Windows folder, or something goofy like that I can see where you got confused. But I tried to be explicit that it was 15 files totaling about 20GB in size.
I'll let you all know how the new drive performs. I am partly worried it is the motherboard, but crossing my fingers it isn't.
Old Hippie
6,361
This is no MB problem.
If there is a problem it's with the drive.
Copying the Windows Image backup. 20GB over 15 files.
I thought you were copying a Windows image backup which would have all the small files windows contains.
Let's just see how the new drive performs.
Hopefully it'll do better.
coder_t2
92
Got the new drive a couple weeks ago. All looks good so far. Copies the Backup folder at like 30MB/s. And it does well in my other tests.
