Originally posted by: xtknight
Any old UHF antenna will work (yeah, the ones decades ago) for HDTV. I think a Yagi UHF antenna+amplifier is the best you can get?
I use a regular $5 Walmart UHF antenna (no amplifier) and it picks up my locals fine if I mount it high enough. My dad's attic antenna can receive a lot better though.
I have a ghetto HDTV setup here. $5 indoor Walmart antenna mounted (5 feet from floor) on a lamp light with scotch tape, with the wire flowing right down to my tuner below. From there it goes to my LCD's secondary D-sub in port and Audigy2's line-in. Works good, but I have to turn the lamp around to receive different channels. :laugh: I can get 85% signal strength at max most of the time. One problem: if anyone touches my scotch-taped antenna I'm gonna be pissed. It takes so long to position that thing right.
What I wonder is how the 'HDTV'-coined antennas are different than UHF ones. They just come with a built-in amp and 75->300 Ohm converter (whatever it's called 2 prong->CATV) or what?
