Scenario: I just bought AIW 7500. I will game a bit, but I am really excited about the capture capabilities. I used to use a Dazzle DVC for capture, which is Mpeg1 of course. I started a Star Trek collection, and was able to put one episode on a CD at a better bitrate than VCD, with the commercials edited out. It was a beautiful thing, except because the video was compressed in real time, it didnt edit so good. I had lip sync problems frequently.
So, with my AIW 7500, I have a chance to start from scratch, get it right, and at a better quality standard to boot. If my understanding is correct, I will need to capture on raw/AVI settings to ensure I dont get the audio sync problems if I am editing. True?
How big a hard drive or partition should I have dedicated to this task? One hour show, in case you didn't know.
As for longer captures, I am hoping that if I'm capturing a full movie, off HBO fer instance, that I can use real time encoding since it wont need any editing. True?
