Since I have 4GB of RAM and XP only sees 3GB, I have decided to move to Vista Business 64-bit. On my current computer, I have a 80GB primary drive which XP and my applications are installed on. I also have a 500GB secondary drive that possesses the contents of my My Documents folders and the Shared Documents folders as well as some other folders for other data.
My plan is to simply delete the partition on the 80GB primary drive and install Vista on it from scratch. That part I am comfortable with. But I had some questions about the secondary drive. I understand that under Vista I would not, by default, be allowed access to my former My Documents folders until I would take ownership of those folders with my new user, but what about all the other folders that were manually created on that drive?
Currently, Administrators, CREATOR OWNER, Everyone, SYSTEM, and Users have permissions to the E:\ partition by default and those permissions are inherited everwhere except the folders that represent Shared Documents and My Documents.
Don't the SIN numbers of the groups change each OS installation? I imagine Vista wouldn't see those groups as the same thing that they were under my XP installation.
I can fix all that if it's just a minor permissions issue, but I'm just concerned that after I do this that my data would be irrecoverable. Please abate my fears. Thanks.
