Twinpeaksr
After almost 6 moths of thinking, research and input from quite a few other people, I am closing in on the replacement for my Old dual MP system I just sold off. Any input would be great. I am not doing a lot of games, but have been known to at times. I do work with CAD a good amount, and do Electronic Simulation and Development. Other than that, general use, stable, with lots of apps open at once. No overclocking (would rather have stability).
I decieded that I am spliting the system into 2 systems, Workstation and Server. Workstation will be on XP Pro, Servier will be on Fedora 4 (though I need to learn how that works). Server is just a file server, and maybe later I will create a web server on it, not sure.
The Big questions is the Workstation Video, Should I use the 7600GS or an FX560? I will be doing CAD, but I still want to be able to do games if i feel like it. Everything else should not have much effect with either card. I just don't want to blow and extra $150 on a Card that does not improve the CAD work I do.
Let me know input, thoughts and ideas, I know you guys have a wealth of knowledge, I am still coming back up to speed on this (Last system I built was 2001)! Thanks!
Workstation:
-MSI 975X Platinum Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail
-Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
-mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit System Memory Model 996527 - Retail
-MSI NX7600GS-T2D256E Geforce 7600GS 256MB GDDR2 PCI Express x16 Video Card - Retail
-LG 16X DVD±R Super-Multi DVD Burner With 12X DVD-RAM Write Black E-IDE/ATAPI Model GSA-H10N - OEM
-Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
-FSP Group (Fortron Source) AX450-PN, 12cm FAN, version 2.0, 2 SATA, PCI Express, 450W Power Supply - Retail
-AMS CF-2229BK Black Steel ATX Mid Tower Computer Case - OEM
2 - ViewSonic VG2021m Black 20" 8ms LCD Monitor - Retail
-TRIPP LITE OMNI900LCD 900 VA 475 Watts OmniSmart Digital UPS - Retail
$1700
Server:
-Intel SE7230NH1 Socket T (LGA 775) Intel E7230 ATX Server Motherboard - Retail
-Intel Celeron D 326 Prescott 2.53GHz LGA 775 EM64T Processor w/ Execute Disable Bit Model BX80547RE2533CN - Retail
2 - CORSAIR ValueSelect 512MB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model VS512MB667D2 - Retail
-Areca ARC-1220 PCI-Express x8 SATA II Controller Card - Retail
-Seagate Barracuda 7200.9 ST380811AS 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
6 - Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM (RAID 5 or 6)
-Microsoft K48-00019 Black PS/2 RF Wireless Optical Desktop Pro - Retail
$1800
Workstation:
$1700
Server:
$1800
