2GB USB 2.0 thumb drive vs. hard drive vs. i-ram
ThePiston
861
Obviously i-ram drive would be fastest, but what about the thumb drive vs the hard drive? I have a folder that my main business program accesses from and it's 1.2 GB. It is full of different databases that the program accesses and it takes forever on a normal hard drive. I am considering putting the folder on an i-ram drive, bu tthey cost so much. Do you think a 2GB USB 2.0 thumb drive would be a lot faster than the hard drive? I'd use is just like a separate hard drive and put that folder on it.
jondercik
87
No. they dont deal well with alot of writes. If it is only 1.2 GB and it takes forever to access something is wrong, that isnt that big.
CrashX
1,125
USB flash has a limited number of writes, and they aren't that fast.
Maybe try a Raptor?
Bobthelost
4,360
An external USB drive, flash or not, will be much slower than an internal drive. Defrag it.
t3h l337 n3wb
2,698
USB 2.0 maxes out at 60 MB/s I believe, so that alone is a bottleneck. You also have to factor in distance traveled and other things, so an internal hard drive will always be faster.
ThePiston
861
i'll try an i-ram drive next, i just need better access times - not to mention i'm using a poorly written proprietary program that uses MS Access DBs
Matthias99
8,808
Unless you're already maxed on on RAM, add more RAM and create a 1.5-2GB ramdrive, then run the database from there. Cheaper and faster than an i-RAM. You'd have to sync it with nonvolatile storage every now and then, though.
ThePiston
861
Huh? You can create a ram drive using normal system ram without the i-ram hardware??
What about using those super-fast CF cards for pro photographers... one that's 2GB? Those must be fast, right?
Cerb
17,484
33
86
If you want faster performance with a database, there is a 4-letter acronym calling out to you: SCSI. A decent u160 or u320 controller, and a moderately-sized new or used 10k drive, and you aught to be doing very well, beating a Raptor.
The fast CF cards are fast for flash, but that ain't fast compared to a normal HDD. Last-generation SCSI would be an inexpensive and effective way to go, I think.
Also, yes, you can create a RAMdisk. It will use some of your RAM (so you want to have plenty installed), but look like a plain old drive to your software. The iRAM's main thing is the battery, allowing it to be nonvolatile to some degree.
ThePiston
861
yeah, i just looked into SuperVolume which mirrors a drive you specify in ram... it reads and writes to Ram at speeds of the ramdisk, then later it writes to the HD for backup so it's totally safe.
