Originally posted by: Mark R
I'm looking for a GF4 card (probably Ti4200 or Ti4400).
Which ones have good 2d quality - i'd be looking to run at 1800x1440 @ 90 Hz (if I decide to get the monitor I want 🙂 ) and want something that will provide crisp clear text at that resolution/refresh.
Originally posted by: Brian48
The GF4's have excellent 2d quality. I've had a Visiontek ti4600 at one time and currently have a PNY ti4200 in one of my backups. The 2d quality is very close to that of my R8500 and 9700 Pro. The ATI cards are still slightly better, but the differences are insignificant in my opinion and you really have to look for them.
Guess I was being a little overoptimistic with the res/refresh. Not even the parhelia will do that.
The only card I've found that will is the Radeon 9800 pro.
Guess I'll have to settle for something a little less.
Originally posted by: mboy
...the latest 53.45 drivers in 2d. SURPRISINGLY good!
Are you sure about that? My 8500 will output 120hz at 1600x1200 (it has an option for it, I've never tried it tho). Any card with at least a 350mhz ramdac should output at that resolution/refresh rate. Check out the product specs.
Yup - checked all the datasheets that I could get hold of. All geforce 4 cards 1920x1440 (closest res) max 75 Hz. Same with parhelia. Same with all ATI cards except 9800 Pro which manages 90 Hz.
Guess your 8500 card has a better RAMDAC than the 9x00 series.
