Hi
asrock a320m hdv r3
Cannot solve this problem
when there is no load pc works fine
but in 3dmark bench tests freezes after 10 to 30 seconds
nothing is overclocked
bought it new from ebay germany
updated bios
updated amd chipset
latest rtx drivers
etc
is this cpu defective?
How do I hard throttle to stock 3.7 Ghz?
I need to disable auto boost right?
PSU 700 Watt
Please help
logs are here log.zip
here is temp logs hwinfo64 https://drive.google.com/open?id=1tjioVMMy76EsaT7_dhARexZYLTbQr4Wd
specs https://drive.google.com/open?id=1XZUTJcdlc3zmiqG3xRCXY-vVuVVcdTL5
temp logs and stats are here https://drive.google.com/open?id=1r2xUtCTWQ0AyW0-qwPSO-0JYSrGMSHGW
AMD Ryzen 7 2700X
[General Information]
Processor Name: AMD Ryzen 7 2700X
Original Processor Frequency: 3700.0 MHz
Original Processor Frequency [MHz]: 3700
CPU ID: 00800F82
Extended CPU ID: 00800F82
CPU Brand Name: AMD Ryzen 7 2700X Eight-Core Processor
CPU Vendor: AuthenticAMD
CPU Stepping: <AMD Zen/Pinnacle Ridge>
CPU Code Name: Pinnacle Ridge
CPU Technology: 12 nm
CPU Thermal Design Power (TDP): 105.0 W
CPU Max. Junction Temperature (Tj,max): 85 °C
CPU Platform: AM4
Microcode Update Revision: 800820B
SMU Firmware Revision: 43.20.0
Number of CPU Cores: 8
Number of Logical CPUs: 16
[Operating Points]
CPU HFM (Base): 3700.0 MHz = 37.00 x 100.0 MHz
CPU Boost Max: [Unlimited]
CPU Current: 4091.2 MHz = 41.00 x 99.8 MHz @ 1.3438 V
CPU Bus Type: UMI
[Cache and TLB]
L1 Cache: Instruction: 8 x 64 KBytes, Data: 8 x 32 KBytes
L2 Cache: Integrated: 8 x 512 KBytes
L3 Cache: 2 x 8 MBytes
Instruction TLB: Fully associative, 64 entries
Data TLB: Fully associative, 64 entries
[Standard Feature Flags]
asrock a320m hdv r3
updated bios
updated amd chipset
latest rtx drivers
etc
PSU 700 Watt
Please help
AMD Ryzen 7 2700X
CPU ID: 00800F82
CPU Platform: AM4
[Operating Points]
CPU Bus Type: UMI
[Cache and TLB]
