Good Morning Forum-Goers,
I come to you all seeking advice. I have been wanting to get a 27" monitor for quite some time now and have really been eyeing these QNIX 27" monitors.
Should I consider one of these monitors? If so, I seem to be torn between:
http://www.newegg.com/Product/Product.aspx?Item=9SIA2RY...
and
I cannot tell what the difference is between them though. Can anyone help me on this?
Also, I would like to run a two monitor setup; however, my second monitor is a Asus 24" 120hz monitor. Can a gtx670 FTW, run both the 24" and 27" at 120hz (assuming I can stabilize the 27" at 120hz)? To be honest, I do not really intend on running dual displays while gaming, I would rather have my second monitor for chatting, netflix, etc, while playing on the 27".
Thank you for any suggestions/advice.
and
