Question 27 inch 1440p freesync monitor help
elkido122
275
I'm looking to get a 27 inch 1440p freesync monitor to pair with my 6800xt . I've been looking at the gigabyte g27q and the viewsonic VX2758-2KP-MHD and can't decide which one to go with. My budget is no more than 300 bucks , and I don't need all the hdr stuff some come with .. suggestions ? Thanks
Glo.
5,930
4,991
BenQ EX2780 in your region is how expensive?
Basically any 27 inch, 1440p, 144 Hz monitor with IPS panel from Innolux will fit the deal, so...
Borealis7
2,901
205
check out the site: https://www.rtings.com/
some recommendations:
LG 27GL850
Lenovo Legion Y27q-20
MSI Optix MAG271CQR (curved)
GIGABYTE Auros (Gsync)
ASUS Predator (forgot the model name)
AOC CQ27G2
many more options, read the lists on that review site.
i have the Lenovo Legion, its a good budget option, nothing out of the ordinary, does the job.
Reactions: Mopetar
Glo.
5,930
4,991
Gigabyte M27Q is quite possibly the best monitor for around 300$ that has 1440p and at least 144 Hz refresh rate.
funboy6942
15,368
418
Here you go.
Do not be scared of the name, research, watch many reviews, and you will find that is the best bang for the buck. They also have high HZ 16:9 units as well under 3 bones, and hell I may just sell my 32" curved one with 185 HZ with 1 DP, and 3 HDMI with one being a 165HZ 2.0, the other 2 are 1.4 144hz, but it is in the FS forum, and it may be used but never abused, flawless, with blacks being black, and colors that just pop off the screen ever so vibrant.
