256MB Creative Nomad MUVO TX For Only $159.99 @ Creativelabs.com
bman46
256MB Creative Nomad MUVO TX For Only $159.99 @ Creativelabs.com - Coupon Code ($20 Off $99) Can Be Found At My Favorite Coupon Site!
Here Is Some Info On The MP3 Player to save you the time of going to the website if your not interested:
Ultra-light Digital Audio Player and Super Fast USB 2.0 - Digital Music Made Simple!
MuVo® TX is an ultra-light, high-performance Digital Audio Player with super fast USB 2.0 that lets you enjoy hours of WMA or MP3 digital music anywhere. Offered with 128MB, 256MB or 512MB of built-in flash memory, MuVo TX is equipped with super fast USB 2.0, so now you can transfer music and data up to 40x faster than conventional USB 1.1. And, because it gives you skip free playback, it is designed for flawless performance during exercise and other rigorous activity.
Simply attach MuVo TX to any PC or notebook with the built-in USB 2.0 connector and drag-and-drop your music files to your MuVo TX in lightning fast speed. You can also use it to carry documents, photos and any other data files between computers at home, work or on the road. Use the handy built-in mic to record up to 32 hours of voice messages, notes and conversations. Plus the high-resolution backlit LCD provides full track information (ID3 tags), access to custom settings and allows easy folder navigation with the convenient rocker button. Load it, snap it and go!
128MB holds up to 4 hours WMA or 2 hours MP3 music when recorded at 64kbps (WMA) or 128kbps (MP3) other bit rates are supported as well.
256MB holds up to 8 hours WMA or 4 hours MP3 music
512MB holds up to 16hrs of WMA music and 8 hrs of MP3 music
Plug-and-Play removable drive
No cables - Handy built-in USB connector
Super fast USB 2.0 - transfer music and data up to 40x faster than USB 1.1
Skip-free audio, perfect for active exercise
Crystal clear, static-free sound, > 90dB SNR
Comes with high quality Neodymium earphones
5-band custom equalizer or 4 presets
High Resolution LCD shows player status, track details (ID3 tag support) and more!
Easy menu and music navigation with rocker button
Full play mode control including Shuffle modes and Resume
Easy folder / album navigation
Rotate LCD easily for left or right hand operation
Easily share your music, photos and documents anywhere
Works as a USB Flash Drive with any PC or Mac
Stores all your important documents, photos and presentations
Holds the equivalent of 88 (128MB model), 176 (256MB model) or 352 (512MB model) floppies
Built-in microphone records up to 8 hours (128MB model), 16 hours (256MB model) or 32 hours (512MB model) of high quality voice recording. Perfect for capturing ideas, dictating memos and saving reminders anytime, anywhere
Hope I was able to help SOMEONE!
Happy Shopping!
Very tempting... I've been planning on buying one of these for the past 2 months. Maybe this is the push I need. 🙂
Cool, I saw today that they got a different coupon for 10% off $49 - Not as good, but maybe helpful to someone buying something more expensive like one of the higher capacity MP3 players!
