I have an existing 120gb installed on IDE1 on mobo. That wire goes to the 120gb and a dvd-rom. On IDE2 on the mobo we have a burner. I bought a 250gb and can't get it to install it any way I tried. The 250 has a promise ultra card. When I disconnected the burner and put it back...the computer just hangs at startup trying to read the drives and wont go any further. I had to disconnect the burner for the computer to start. This is how I had the computer in the first place and it wont even do that. The ultra card wont even show up on my computer anymore even with the drivers in my computer. When the ultra card is plugged in and new drive is in it, it'll scan and say there are no drives attached to it. The first time I attached the ultra card it showed up, but now it's gone. My computer won't even start up now when my burner in my IDE2 is plugged in. How can I fix that problem and get my 250gb installed using the promise ultra card? This is really annoying me. Everything is on cable select so there isn't a problem with jumpers. I dont have a floppy disk drive so I attached it to use the diskettes that came with the drive and the floppy disk drive wont even show up either.
Thanks in Advance.
Thanks in Advance.
