2500K temps on water look alright?
sticks435
Hey all, just got my water system put in yesterday and have been folding on it for about 13 hours or so. Thing is, 2 of my core temps (1,2) seem to not be much better than my air setup, while 0 and 4 are almost 8-12C cooler. According to RealTemp 3.70, the max temps are 54/60/60/55. CPUID Hardware monitor says 51/58/56/54. When I applied my MX-4, I did a vertical rice sized line. I just looked up the die shot of the 2500K and it looks like it's horizontal, not vertical like I thought. I'm wondering if I should reapply the TIM to try and bring those 2 middle cores down closer to the outer 2. On my 212+, my cores were right around 63 at full load.
Using a Raystorm block and D5 pump set on 2. Nexxos UT60 with XSPC fans pushing in from the top set at 1100RPM.
I also tested 50 minutes of Prime 95 small FFT's, realtemp max temps are 59/67/66/62 and HWM are 57/65/63/60. I dunno what is going on.
