I already made the best choices from the online shops in his area - it's his choice to ignore it and make his own selections. Most people feel happier having made their OWN decision anyway because it's their mind doing it, not following someone else's suggestions. It won't be the best value, but he'll be happy. Whatever... do what you want.
First of all I really appreciate every member participated in this thread & took from his time & thinking to help me in my new build & special thanks to these two members "Insert Nickname" & "Blue Max" who were so much helpful , honest & devoted.
Spend much less on a processor almost as fast (for your needs, you wouldn't see the difference) and put the money saved into a good video card.
Secondly to Mr "Blue Max" ... I didnt ignore your help at all & if you re-read my replies, you will find that I followed your suggestions & your advice mentioned in the above quote but according to my budget plan I mentioned from the start. ( I gave-up the i3 that I was going to buy from the start after reading your suggestion & decided to buy the GTX750 that you also suggested)
If I followed this plan + the 4GBRAM (300LE) + case with decent PSU (350-400LE) = 2600LE which I cant afford in the current time , so I made my choice to lower the CPU & the Mobo a little bit to get the advantage of better graphics card as you advised
According to the local store at my city which I bought from, the G3220(450) + Gigabyte-H81(550) (ASRock is not available) = 1000 LE
While G2030 + Gigabyte-H61 = 800 LE
The 200 LE difference helped me in bying the graphics card
Another issue I want to make clear is that almost all the prices at "Egyprices.com" are from stores available only at Cairo (the capital) which is about 300 kilometers from my city
. That is why I bought from a local more expensive store.
One last thing , AMD processors & motherboards are not popular in my city & it's not easy to find them & they are also very overpriced as you mentioned.
The AMD APU's are very overpriced in your area. You get better value with Intel...
I tried to explain why I did so & make things clear & again thank you a lot Mr "Blue Max" . Hope to be friends once a day
. That would be an honor.
