24x CD burners WILL NOT work with < 24x media ?!?
Kwad Guy
3,478
So I picked up one of those QPS 24x10x40 drives at
CompUSA the other week (rebadged Sanyo BP1500, indentical to TDK
24x10x40 drive)...I whipped out my "trusty" CompUSA generia CD blanks
and copied a test disc (Win98SE install disc, in fact). Seemed to
copy OK. Next I copied a music CD (Patty Smythe's greatest hits,
in fact) onto one of those PNY 16x rated discs...That seemed to copy
OK, too. (By seeming to copy OK, I mean they copied without reported
error, and when I reinserted them they were recognized and spun up
properly).
HOWEVER, upon further testing, both discs are riddled with errors and
useless...
So I guess you really NEED to use 24x rated media...Drat...A good reason
not to use a 24x burner (or else to use it in 16x mode)...
Kwad
FuManStan
668
High quality 16x media will work alright though. I've heard that old fujifilm 16x works fine at 24x
Ythan
68
I used to work at CompUSA. The PNY media is worthless. Try 16x Imation or TDK media. I use both with my 24x TDK and I've never had a bad burn.
-Y
