24pins ATX PSU help
hixen
i got myself a
Fortron/Source Powersupply ATX rev2 400 W 120mm, 24pin,SATA Special Edition
which turned out to be wrong..
i should have gotten a
Fortron/Source Powersupply ATX-400W OEM 120mm, SATA Special Edition.
But know i'm wondering if I can use this converter.
Adapterkabel 24-pins EPS till 20-pins ATX, 10cm (it's in swedish)
Converter 24-pins EPS to 20-pins ATX, 10cm
So my questions are can i use this converter and is it safe? what does EPS stand for.
You should be able to use the adaptor fine with no problem. EPS power supplies are usualy used with server and high end workstation motherboards.
thx alot man, just hope now they have them in town, i really dont want to wait another week to get my new computer up and running.
