- Mar 30, 2007
- 13,559
- 8
- 0
Picked up an extremely clean for the Midwest S13 in trade for my LS400 Lexus. The fact that the SR20 in the engine bay wasnt running wasn't a big deal since I have wanted to do another 240 for some time and this seemed like the perfect car at the wrong time.
After some consideration and sweetening by the PO I did the deal. I have a SR20 red top stock pull from a old part out with strut tower rust that I knew was solid so that was the plan.
The PO had told me there were issues with engine and another shop told him he needed a full rebuild. While my lexus is worth more than a roller S13 the fact that the car had decent suspension, low miles on shell, good intake and HKS 272 cams and many quality parts that I could use sealed the deal.
When we were inspecting the car when it first arrived we had a hard time finding what was wrong with a basic look over. After the deal was done we started to prep the car for the pull when I decided to run compression. Was great. Pulled plugs and threw in some NGKs and used different coil packs and boom it fired up.
Its running outside right now.... Here's a few ext shots!
Had a cancellation this morning so the car is on the lift right now with a dye treatment in the oil to see where these little leaks are coming from. Oil pressure is good. Gonna check for boost leaks after work today.
:thumbsdown:
