2405fpw HELP
Fenriss
just purchased a 2405FPW from another user and i would like to know how to check the screen.
this is my very first Flat panel screen and i want to know how you go about giving your LCD monitor a thorough checkup to see if there are any Backlighting and or dead/stuck pixels issues. is this done visually or are there any programs that can assist in this?
LMK.
Set your XP screensaver to 'blank' and wait time= one minute. After a minute you'll have a black screen. That should give you a chance to see backlighting. If you don't see it with normal usage, you might not want to go off looking for it cause you'll probably find some.
I wouldn't even bother to look. Whats the point. If you aren't noticing it just by normal usage when you DO find something it will annoy you...
