Ok, I currently have the Asus A8N Sli board and my PSU has only the 20 pin connector whereas the board has a 24 pin power connector, what is the benefit if any of using a PSU with 24 pin connector?
Patrick
Just hook the cable where pin 1 meets socket one. It should work fine. Read your manual. It will tell you all you can f*** up that ASUS does not want to be liable for.
From what I've been told by my computer tech friend, if you buy a 20pin to 24pin connector, you should be fine. Tt makes one, as do a growing number of companys.
