Originally posted by: flexy
I beg to differ. It appears that the different slots in a 24 pin main plug have different leads...+3v, ground, +5v, etc. If the pegs are misaligned it seems to me that you could easily cook the board and possibly anything drawing power from it...
whats the question ? 🙂
Yes..the 4 extras are +5, +3, +12 and GND...and yes, if you screw something up there you might fry something 🙂 But this was not really the question or what i said.
I said that (IMHO) most new boards and pci-ex cards should work fine with only the 20p plug and the card getting its power thru the two unused molex with the usual pci ex power adapter. Correct me if i am wrong.
You're not getting it - look at the diagram. The extras are NOT a +5, +3, +12, GND on the A8N. They are +3, +3, +3, GND, meaning your +3.3 devices would be woefully undernourished, leading to huge stability problems.
How do you know what the extra connections are on other boards? Maybe they will be what you said, and maybe not, but either way it's the motherboard not getting the power it needs. I understand what you're saying about the card not NEEDING the extra power, but that DOESN'T CHANGE the fact that the dead leads may screw something else up. I am going to ask you these questions again, please try to answer them, or admit you don't know, one.
1) If the board will work fine with a 20 pin plug even though it's main plug is a 24 pin, WHERE WOULD YOU PLUG THE 20 PIN PLUG IN?
2) Since this will leave dead leads, how would you know what leads are dead, unless the mobo manufacturer gives you a diagram like ASUS did?
3) If you know these leads are dead, how can you be sure the board will function correctly?
4) Will not having dead leads on the main power plug cause the devices to try to suck too much juice through the leads that ARE plugged in, thus hurting both the power supply, the mainboard, and the devices, and possibly destroying all of them?
I kind of see what you're saying....if you move the plug "up" in the 24p main connector, you could leave one lead of each rail dead, plus a ground. But wouldn't this cause the retard-proofing latches on the main plug and the connector from the PSU to misalign, thus not allowing you to plug the connector in unless you did some "surgery" on the retard-latch?
Furthermore, trying to do this without a diagram of the main plug is risky at best, unless they're all on some kind of standard - being that PSU manufacturers need something to build for I imagine that's the case, but one never knows...
