- Oct 16, 2015
- 7
- 0
- 0
Hey, my first post here
I currently have a I5 4670, 8GB DDR3 RAM, two 500GB HDS and a Soundblaster 5.1 aswell as a GTX 750 TI with a standard Benq 1080p/60Hz Monitor but I want to upgrade my GPU for the Pascal/next AMD generation and I'm thinking about getting a middle-class lower-enthusiant class GPU (aka the next gen GTX 970/R390/390x equivalent) and get a higher resolution Monitor to go along with it if possible.
Now the the thing is, my Computer desk has two stands for CDs/DVDs which makes the most space available at 29 inches (28 inches for Monitors) so I'm going for a smaller 24 inch- 27 inch monitor max. I've read things on the various websites that 4k and 1440p will not look much better than 1080p on those sizes so I need some input. Since I'm already using 1080p I wouldn't feel any bad staying there, but from what I've seen 1440p is better, 4k even moreso but I'm not sure if that applies for smaller sized-monitors. Then again, is 4k even an option for middle class next gen GPUs? Or should I stay @1080p and get to play at Ultra for Years? Or can 1440 already safely handle good settings on that level of cards. Thing is I don't want to upgrade for at least 3 Years so I need the best bang for buck at enjoyable settings. For me enjoyable is 60fps dipping to no lower than 50fps...and good graphics.
I've also heard that you need more RAM for higher VRAM so I'm thinking about buying another 8GB RAM stick aswell, mine is @ 1600 but I'm not sure about how to upgrade RAM as people said it can fry your PC if you go with two different ram CLs or frequency (would like input on that aswell, unless 8GB is enough).
