I was able to get two of these from two different Staples locations in northern NJ. They work well with DVI, but I can't get either to work through HDMI at all. Sometimes, my Win 7 and AMD CCC graphics managers detect the display through HDMI, but can't actually show anything through either dupication, extension, replacement, nor Eyefinity. Using my TV setup (receiver, blu-ray, cable STB and TV with HDMI) and laptop (also HDMI), I've tried various combinations of cables, sources and displays to narrow down possible culprits but every other piece checks out OK.
Another oddity I found was that the On Screen Display doesn't work unless you've already got a working connection (as I have through DVI.) Is this the way it's supposed to work? I'm guessing no, because how would one switch inputs if autodetect source was off?
I noticed some similar problems mentioned on the HP support forums, but none of the suggestions have worked (updating monitor driver, resetting monitor, etc.)
A DVI setup is all I need for now, but it bothers me that the HDMI doesn't work. I guess I can try to exchange, even after the sale is over.
Is anyone else having this same problem with their recent 2311x purchase?
