23-24" monitor help!
Hello, I need help in choosing a new monitor that will be primarily used for gaming(high end wow raiding). I'm currently playing on a Benq 19" that I've had for around 6 years and since I just recently built my new SB rig, I need to get an upgrade.
I don't have a lot of money but my budget is around 200-230, I know that wont get me the best monitor but it should get me a decent one. Also, are there any good sites out there for choosing monitors? If there is I haven't been able to find it.
so far I've come across these monitors that are in my budget range and from a store where I live.
http://www.canadacomputers.com/produ...item_id=021406
http://www.canadacomputers.com/produ...item_id=035364
http://www.canadacomputers.com/produ...item_id=036223
http://www.canadacomputers.com/produ...item_id=037836
http://www.canadacomputers.com/produ...item_id=034992
http://www.canadacomputers.com/produ...item_id=035913
I really do appreciate any help or advice I might get from you all, thanks again. Also, im not sure how much this information will help but my pc specs are:
i5 2500k @ stock(will be ocing to 4.5 once i get my updated mobo)
gtx 460 @ stock
4gb or ram @ 1600
