220V Monitor running on 110v
chinesewaterboy
Hi, newbie with a newb question here.....
I've got a Samsung p2450 that I bought in China, and the current here is 220v.
I'm wondering if my monitor will still run the same off the same power cord under 110v current when I'm in North America.
My question is basically if it will appear under-powered (dim?).
There's no converter on the cable which is why I'm curious if it's going to be 110-220 compatible.
Thanks in advance for any and all help!!!
chinesewaterboy
thanks for the quick reply, one last question though.....
My monitor's packaging, manual and the monitor itself say SyncMaster P2450 (no H).
I bought it in Beijing, would the power supply be the same?
Harvey
Administrator<br>Elite Member
67
First, the VOLTAGE in Beijing is 220 v, not the current.
Per the specs quoted by PottedMeat, your monitor has a universal power supply designed to work on any wall voltage from 100 VAC (Japan, etc.) to 240 VAC which includes some parts of Europe that haven't yet converted to the more recent Euro standard of 230 VAC.
You won't need a voltage converting transformer, but you will need a power cord with a plug that matches the connectors where you are or an adapter to convert the plug configuration to the one you need to match local wall sockets, which probably look like this:
More info, here.
Type I
AS/NZS 3112 (Australasian 10 A/240 V)
For more details on this topic, see AS 3112.
Australasian switched 3-pin dual power point (socket)
This plug, used in Australia, New Zealand, Fiji, Argentina, Solomon Islands and Papua New Guinea, has a grounding pin, and two flat current-carrying pins forming an upside down V-shape.[19] The flat blades measure 6.5 by 1.6 mm (0.256 by 0.063 in) and are set at 30&#176; to the vertical at a nominal pitch of 13.7 mm (0.539 in). Australian and New Zealand wall sockets almost always have switches on them for extra safety, as in the UK. An unearthed version of this plug with two angled power pins but no earthing pin is used with small double-insulated appliances, but the powerpoint (wall) outlets always have three pins, including a ground pin.
There are several AS/NZS 3112 plug variants,[20] including ones with larger pins and/or differently shaped ground pins used for devices drawing 15, 20, 25 and 32 amps. These sockets accept plugs of equal or of a lower current capacity, but not of higher capacity. For example, a 10 A plug will fit all sockets but a 20 A plug will fit only 20, 25 and 32 A outlets.
Australian 2005 standard power plug
Australasia's standard plug/socket system was originally codified as standard C112 (floated provisionally in 1937, and adopted as a formal standard in 1938), which was superseded by AS 3112 in 1990. As of 2005, the latest major update is AS/NZS 3112:2004, which mandated insulated pins[21] by 2005 at the point of sale in all Australian States and New Zealand. However, equipment and cords made before 2003 can still be used.
Chinese sockets accepting plug Types A, C (upper) and I (lower, standard)
CPCS-CCC (Chinese 10 A/250 V)
Although the pins on the Chinese plug are 1 mm (0.039 in) longer, the Australasian plug can be used with mainland Chinese socket. The standard for Chinese plugs and sockets is set out in GB 2099.1&#8211;2008 and GB 1002&#8211;2008. As part of China's commitment for entry into the WTO, the new CPCS (Compulsory Product Certification System) has been introduced, and compliant Chinese plugs have been awarded the CCC Mark by this system. The plug is three wire, earthed, rated at 10 A, 250 V and used for Class 1 applications.
In China, the sockets are installed upside-down relative to the Australasian ones.
China also uses American/Japanese Type A sockets and plugs for Class-II appliances. However, the voltage across the pins of a Chinese socket will always be 220, no matter what the plug type
mfenn
22,400
www.mfenn.com
You can check the sticker on the back of your monitor to be sure, but I'm 99&#37; certain that you'll find the same think as what PottedMeat showed you.
What's even more convenient is that it appears to use a standard IEC cord instead of a hardwired power card. You don't even have to bother with a plug adapter, just grab an IEC cord with US plugs and be done (most people have a bunch of these laying around).
