- Jul 6, 2007
- 6,799
- 1,103
- 126
Hi, I'm looking at two 22" HDTV models, I want ti use it as TV set and use it as computer monitor (which should support 1680x1050 resolution)
But I'm confused by the tech spec.
Zenith 22" model 22LCD3
http://zenith.com/products/lcd-tv/22LCD3/ resolution 1366 x768
But here says native resolution 1680x1050
http://64.131.74.244/images/pr.../22LCD3_spec_sheet.pdf
Vizio 22" model VO22L
http://www.vizio.com/productDe....aspx?id=1788&pid=1508
Supported TV Formats
1080i, 720p, 720i, 480p, 480i
Native Panel Resolution: 1680 x 1050
Supported PC Resolutions
1366 x 768, 1024 x 768, 800 x 600 <-- does this mean if I use it as computer monitor, it's maximum resolution is 1366x768? And why the native panel resolution is 1680x1050?
I'm really confused.
So exactly what is the maximum resolution if I use these HDTV as PC monitor?
Can anyone help? Thanks!
