20wmgx2 some settings help
farp96
What is a good setting for the nec 20wmgx2? I'm looking for brighteness and contrast and sharpness. Also what do most people use for the color settings, native SRGB etc...
Thanks
Also what is the pixel clock total for the 20wmgx2? If I make it 75hz using the force method it says the pixel clock is at 183hz
60hz refresh is the native refresh.
Only use the standard mode with Advanced DV mode on. This will give the most accurate colors (I found out quickly about the banding that happened when you select other modes)
Use the default sharpness which should be 16.6.
Contrast should always be @ 50%
Brightness seems good to me @ 50% during the day and 30% during evening.
For RGB I use:
R:96.4
G:98.8
B:95.6
That's as close to 6500k as I can get it with my eyes, a sheet or paper, and a light bulb 😛
I've had this since its US launch -- I hope you enjoy it as much as I have 🙂
