Hi All,
Building my first SFF and there is only one concern for me...
I have a mATX Power supply that is a mere 200w (it came with the case) it looks of average quality.
My Components are as follows...
P4 3.4ghz PPGA775 Prescott
Intel 915GAGL (Video, Lan, Sound)
512 OCZ EL DDR400 (2 x 256mb dimms)
Intel Stock HSF (Will upgrade to Zalman 7000ALCU)
80GB SATA150 Seagate 7200rpm
HP 300i DVDRW (hacked to a limited NEC 1300A)
No Floppy (saving power)
No Card readers
Wireless Kbd + Mouse (the USB sensor will draw some watts)
1 x 60mm rear exhaust fan (dont know the RPM, one of those 1/2" thick ones)
Things that I am thinking of adding....
ATI X800 XL PCIe
1 x Sunon High Speed 60mm fan (to replace the one above)
1 x 80mm case fan (modified to fit)
1 x PCI Slot cooler (to keep my vid card cool)
I am hoping to get some feedback and some estimates on power usage for the components. Thank you all for helping. I have not put together this thing yet.
Thanks to all that can contribute.
Best Regards,
DuckmanX
No Card readers
ATI X800 XL PCIe
Best Regards,
DuckmanX
