So, I just got this new hard drive from Dell about 2 weeks ago, it had been working fine, then suddenly, earlier today, trying to access certain files on it was causing my system to freeze up.  I tried reinstalling the drivers for the controller card, to see if that was it, and it seems like things have gotten worse.  If there is any way I can save some of the files on this drive, I really need to... there is (was) some pretty important stuff on there.
When I try to access the drive from explorer, I get "E:\ is not accessible. The parameter is incorrect." In fact, the drive label isn't even showing up any more. It just says "Local Disk" now.
Norton Disk Doctor tells me "Unable to access drive E:. The volume does not contain a recognized file system."
When I run CHKDSK from a command prompt, it starts with the "verifying files" bit, and gets to 94%, then starts with "File record segment 43140 is unreadable." and it keeps saying this over and over, increasing by 1 each time... 43141, 43142, 43143, and so on... I'll let it run for a while and see if it does anything else.
So, does anyone have any ideas here? I have heard putting drives in a freezer to cool them down enough to recover data from them before they heat all the way up again. Would that possibly help in this situation? I am desperate!
Thanks!
Thanks!
