Essence_of_War
My gf has a Mac Pro 3,1 (early 2008) and I think the upper memory riser has died. Is that a serious problem if she is able to use all of the RAM she needs without it?
She had 4x 2 GB RAM DIMMs, and 2x 1 GB DIMMs in it, and it was occasionally giving her blinking power light POST codes, and then she noticed that she only had 8 GB of RAM available.
I booted her Mac Pro in every combination of the DIMMs between the upper and lower riser that I could think of and I found that every DIMM pair was recognized if it was in the lower riser, no DIMM pair was recognized if it was in the upper riser, and if there was RAM only in the upper riser, it would not boot and give only the blinking power light post-code.
I left the top RAM riser in, removed the 2x 1 GB DIMMs, and placed the 4x2GB DIMMs in the lower riser, and she has not encountered a post-code since, and OSX always recognizes the full 8 GB of RAM.
Everything seems to suggest a dead riser, or maybe a dead riser connection, right? Will leaving the dead riser in cause any problems in the long-run? I know that technically having all 4 slots on the lower riser populated but no slots on the upper riser populated is not the correct configuration for a total of 4 DIMMs. The manual calls for 2 slots on each riser to be populated if there are 4 DIMMs, but if it boots and recognizes all of the RAM without trouble, I suppose the worst case scenario is just that it isn't operating in the maximum number of memory channels, right?
