2007wfp factory menu color setting HELP!
lcdman2007
Hi all. 1st post. I received a Dell 2007wfp replacement through warranty.
The monitor color is way off compare to my old one.
I see not much difference inside factory menu setting (menu, + sign, power buttons)
Offset 1 is fixed. Gain, PC blue, red, normal as well as MAC normal presets seem fine to me.
Offset 2 caught my attention, R 73 G 81 B 73, My screen is way blue. I increased Red to 126 (128 and above render the screen way off too with a Green like tint) in order to get the natural color feel like my old monitor, somehow the color is still a bit blue not red enough for my liking.
Anyone has the same monitor could you pls post your Offset 1,2, Gain, PC blue, red, normal as well as MAC normal presets color setting here for me to look at. I just bought a colorimeter which I have yet to learn how to use it.
many thanks!
