2005FPW Wall Mount
cornelp
83
Well I took the bite and ordered the 2005FPW Dell LCD. Love everything bout it. my questions for all U out there.
Does anyone know of a Wall Mount for this LCD? I searched the forums here, looked around the NET, Dell website, and nothing.
i purchased a Sanus Wall Mount before I got the monitor (today) and when I looked at it, the back of the LCD will not work with the Wall Mount. i have 2 differnt kinds, Sanus and forgot the other one's name, but neither one will work. Dell just happen to make it non standard for the non-dell LCD wall mounts.
I really need this, and cant find one. I am gonna keep on searching, but if anyone know of one that will really help me a lot.
Found the links:
http://www.compusa.com/products/product_info.asp?product_code=316986&pfp=cat3
http://www.bestbuy.com/site/olspage.jsp...=4640669&type=product&id=1051806207099
Anyone knows of one that will work with this LCD?
THANK YOU...
Tab
12,145
The second one SHOULD work...
I believe the Dell 2005 WFP is 100mm VESA.
cornelp
83
Neither one would work. I tried em both. The thing is that the LCD has only 2 holes on the top and they do not allign with the wall mount. They are off by about say half inch or so on both sides.
Anyone else know of one that works, or someone has this LCD on a wall mount?
THANK YOU...
L00PY
1,101
Like Tab said, the monitor should fit the 100mm VESA mounting standard. Are you sure you weren't comparing them to the 75mm holes? That would place them at almost exactly 0.5" off on each side. In other words, measure the distance from the center of the holes -- they should be 100mm (3.94") apart.
cornelp
83
Both of the wall mounts states that they support VESA 75 and 100. The LCD according to Dell is a VESA 100 Compliant. I will try again, but got one more question, please.
The Dell 2005FPW only has 2 holes, the top ones. That would be enough to support the Wall Mount, correct?
Just want to make sure I dont make more problems if not needed.
Thank You...
