20 years ago shorty lickens purchased his first digital camera.
File Name : dsc01103b.jpg
Directory : .
File Size : 428 kB
File Modification Date/Time : 2021:06:18 09:03:11
File Type : JPEG
MIME Type : image/jpeg
Image Description :
Make : SONY
Camera Model Name : CYBERSHOT
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : ACD Systems Digital Imaging
Modify Date : 2008:06:21 14:03:21
Y Cb Cr Positioning : Centered
Exposure Time : 1/100
F Number : 3.8
Exposure Program : Program AE
ISO : 100
Exif Version : 0210
Date/Time Original : 2002:10:11 13:10:22
Create Date : 2002:10:11 13:10:22
Components Configuration : YCbCr
Compressed Bits Per Pixel : 2
Exposure Compensation : 0
Max Aperture Value : 3.7
Metering Mode : Spot
Light Source : Unknown (0)
Flash : No Flash
Focal Length : 6.4mm
Warning : [minor] Possibly incorrect maker notes offsets (fix by 39?)
Warning : Invalid PrintIM header
Sub Sec Time : 984
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 1200
Exif Image Length : 1600
File Source : Digital Camera
Scene Type : Directly photographed
Compression : JPEG (old-style)
Thumbnail Offset : 735
Thumbnail Length : 4503
Image Width : 1200
Image Height : 1600
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 3.8
Image Size : 1200x1600
Shutter Speed : 1/100
Thumbnail Image : (Binary data 4503 bytes, use -b option to extract)
Light Value : 10.5
Hold on a second - I need to judge in here to determine if IronWing went outside the parameters and cheated by looking at the EXIF 😛
The rules clearly and/or ambiguously state
If you guys can guess the camera model, or glean it from something, I will confirm or deny your guess.
It's too bad the focal length isn't conclusive. Sensor size and crop factor would put it at ~35mm FF equivalent
Sony P50.
Sorry, I was...... away for a while.
Later I got the F717 but it was one of those with a bad sensor and god damn Sony didnt service it for me. I stopped buying their products for a while out of spite.
Until the a6400 which was actually a great camera EXCEPT for the tiny controls. I have small hands but it seems like most modern bodies are too small even for me.
Here is an pic of all my old Sony cameras, including my first one (upper right), the sony DSC-50 which I got around 2000/2001 I think...she actually still works. The one on the left is an RSC-1 (sold it), middle one is F-707 (still have it) and the last one on the right is an F-828 (sold it). All of these cameras used the same battery which was a very pleasant surprise. I currently have an A9 and an A7 RIV...
umm, no, thats not correct. the one in the upper right does not look like a DSC 50 or P50. I still have mine and its very different.
I was pretty close...Here is a pic I just took of the product label at the bottom of the camera 😎
can't believe you can still buy one one Amazon.. 😱
My current babies:
Sony A7 RIV on left with 200-600 lens with 1.4 t/c
Sony A9 on right with 70-200 F4 lens
also have a Tamron 17-28 F2.8, 28-75 F2.8 and a Sony APSC nifty fifty lenses
