20 Pin ATX PSU Splitter
mgpaulus
1,112
Does anyone know of a splitter that will go from an older style ATX Powersupply
with only the 20 Pin to a newer style with 20 Pin + the 4 Pin (Black/Yellow/Black/Yellow),
so I can put a P4 into an older case/PSU?
Thanks.
Lunyone
482
Originally posted by: mpilchfamily
What exactly are you needing? Sounds like you are wanting to get an adapter that will offer you the P4 power connector right? Well the adapter doesn't give you the power from the 20 pin main connector. It will pull the power from one of the molex connectors.
http://www.newegg.com/Product/...x?Item=N82E16812200084
That's what I was reading from his post. I think you got the same result that I would've gotten.
mgpaulus
1,112
Yep, that's what I need. Thanks guys. I think I'll check and see if Compusa has it, so I can get it locally. Shipping really kills that kind of deal.
