I will send a check for $20 to the person that gives me the cure for my problem. Either you tell me how to fix my computer or you tell me the part that is bad. I will send you the money, I have positive feedback on ebay that you could look up if that counts as any proof.
Here is the problem:
I have been posting messages over the past 2 weeks explaining why my computer doesn't work. I can't install any OS and I have been trying to install 98 and XP. When I try to install 98 the computer initializes, runs the scandisk, says initializing installation and copying files and then returns me to the c:\ prompt. When I try XP it says setupdd.sys could not be loaded, error code 7. I have no idea whats wrong or what to do.
I had a new hard drive sent to me from WD and I get the same results so it isn't a hard drive issue. Although, at the c:\ when I type "dir" I get a message saying No Files Found. This is after I have run fdisk and formatted the drive. I thought this was very strange.
Here is things I have tried:
1. I have tried using a different IDE cable.
2. I have tried both ROM drives.
3. I have tried the barebones of my hardware.
4. I was advised to copy the 98 cd but that was no good.
I know the cd's I'm using work. The computer was originally working but it crashed and I decided to reformat it. I really will send you $20 if you can nail the problem. I will also glady appreciate any advice you can give me.
Here is my system:
AMD Athlon XP 1800
MSI K7T pro-RU mobo
20 gig WD Hard Drive
MSI geforce2 mx vid card
256mb DDRAM
Toshiba DVD
80 pin IDE cables
TDK 16x Burner
Here is my system:
AMD Athlon XP 1800
MSI K7T pro-RU mobo
256mb DDRAM
Toshiba DVD
80 pin IDE cables
TDK 16x Burner
