20+4 pin PSU and 24 pin motherboard, will this work?
alm99
4,560
Are the two compatible or do I need a 24 pin PSU to fit the 24 pin motherboard?
ch33zw1z
38,660
19,213
please post the parts you're using. some 24pin mobos will work find with just the 20pin atx connector.
Aluvus
2,913
20+4 pin power supplies are specifically designed to be compatible with both 20-pin and 24-pin motherboards. You'll be A-OK.
nerdye
16
I'm currenlty running a pentiumD 820 (on a 24 pin, 775 lga motherboard) with a 600 watt 20 pin Ultra brand power supply, and it runs without a problem. From my understanding 20 pin power supplies are fine on 24 pin motherboards, the only concern is y how much wattage your psu has. Just make sure you have a little bit of power to spare on top of all the parts in your system, and you should be just fine.
alm99
4,560
So then when the board I am looking at has a 24 pin power connector and my PSU only has 20 pins, I don't have to get a new PSU?
