I started with Xp Pro - version 2002. After my system developed some uncontrollable glitches I decided to do a clean re-install.
Using the XP CD, I went through the set up process and since I'm now using 512 MB, I decided to convert to NTFS.
After installing I still have the old Xp system plus the new Xp.
* Installations on: C:\WINDOWS and on C:\WINXP
When I bootup I must choose which XP Pro to load. I did another clean install thinking that I would delete one, but it didn't work.
Here are the detailed steps I took in Setup:
1)Continued without repairing system by pressing "ESC".
*Only 1 partiton shows on next page of setup:
C: Partiton1 [NTFS] 38162 MB <29127 MB Free>
2)Attempted to delete the selected partition but unable (partition contains temporary setup files required to complete installation).
3)Pressed ENTER to setup Windows XP on existing Partition1.
*You chose to install Windows XP on a partiton that contains another operating system.
4)Pressed C to continue using Partition1.
* Caution: a Windows folder already exists that may contain a Windows installation. If you continue the existing installation will be overwritten.
5)Pressed "L" to continue.
Setup deletes existing files, copies new files and then reboots.
Setup returns to a GUI page and starts installing Windows for about 40 minutes.
After install I still have 2 operating systems on 1 Drive!
Please tell me the answer is simple and I have been at this too long to see the obvious!
Totally Frustrated,
John
Totally Frustrated,
John
