2 Things/HELP!!! Fonts Messed Up in 1 Computer/ IE Tool Bars on another Computer~!!!!
MainFramed
As you can see in that pic, the fonts are really messed up on my sisters computer. There really big in IE and stuff........why is that? Can someone please help me change that?
As you can also see here.... in that pic there are 2 toolbars in my IE Browser the one at the bottom and top, how the hell they got there i have no clue. if someone could tell me how to fully delete them i would greatly appricaite it!
BTW: there is no program that got accidently installed, i already looked in Add/Remove Programs, and i know you can hide the toolbar by right clicking and turning it off, but i want it gone!!! Please help.
I put both of these questions in one thread so i wouldnt clog up OT 😛
Sorry if it is confusing 😱
I'm assuming you tried view > text size to fix the font size? I don't know about the toolbars but I think there is some way to keeps things like that from installing .. < EDIT: disable install on demand under advanced options > browsing I think.
The huge font
it looks like you got that Accessability crap enabled
to disable assuming you're in WinXP
press Alt + Left Shift + Print Screen
and see if that disables it
As for that extra toolbar, if you don't think any spyware is associated with it and you just want it off you can right-click on any of the toolbars.
A menu will pop-up with checks on it, just uncheck the one that is associated with that crappy toolbar.
Or check your Add/Remove progs list, see if anything suspicous in there.
IE seems to be font size "View -> Text Size" or possibly accesibility stuff as noted already.
Toolbar looks like Spyware cr@p.
yeah the veiw text thing was it/ she had it on LARGE lol thanks guys
