2 second post beep 4 seconds silence 2 second post beep repeat
maxxpowerr
15
I was listening to music. When the music ended I asssumed I had come to the end of playlist. Since monitor had shut down I attempted to access desktop but the monitor remained on standby. I restarted my pc and got a single long post but with a hint of a change in beep toward end. The floppy disc light remained on for until I reset pc and again the same. I had recently, in the last week or more changed the video card. Since the single beep could be either memory or video(normally) I changed the memory first. At this point post began to repeat itself. Long beep(2 secs) 4secs of silence and long beep.
I then put in original memory and changed out the video card. Same thing.
All fans turn on, the harddrive spins up and there is no hint of a burning smell.
ecs k7vta3 mb
amd athlon 2400
evga fx5200 vid(new) geforce 2 mx 64(old)
512mb ram kingston
120gig seagate hdd
40gig western digital hdd
maxxpowerr
15
Ok ..I switched the ram to the other slot and made sure it was seated correctly..it booted up. Now if it is a problem with the ram slot, does this pose a problem in the future?
Now ..in my search for answers I came up with more questions. I noticed on the ECS website that my motherboard has a few versions...How would I be able to tell what version I have. I ask this because I noticed some of the lower versions do not support hdds over 120 gigs. I have had no problem and actually don't know if that means they don't support the size of the drive itself or just the partitions.
I also read that bios for motherboard should be updated if you are adding new hardware ..obviously I added the hdd and have recently added a newer video card.
I have also in the past 3 months upgraded to xp pro. To this point I have not even had a single BSOD or freeze up. Everything has run just fine.
This problem just hit me out of the clear blue and now I wonder if I did not take the necessary precautions ie. update bios?
