Originally posted by: Jaguarfxf
Would it be better to get this x850 XT after tax, shipping, and rebate it comes to about $173 or should I spend about $50 more to get a 7800GT??
Originally posted by: iamwiz82
Got mine the other day and got it installed yesterday. It is fairly loud guys, for those of you worried about noise. It has an odd pitch because of the plastic piping.
Also, mine OCed from 520/540 to 560/590 without any work from me, bumped my 3dMark05 scores 500 points.
Arghh! I was worried about that. Well, mine is scheduled to to be delivered noon-ish today. If my PC is indeed no longer quiet can anybody recommend something specific to calm down this card? It's so nice having a silent PC. Most of the time you wouldn't even know it's running, I'd hate to lose that.
Originally posted by: Don66
I orderd an oem card on the 5th, does it come with the power connector?
Should be here today..
Originally posted by: MAC5000
Got one. I hope it's not to loud! There are silencers for this though right?
On another note, I didn't realize my pricey monitor didn't come with a DVI cable, any suggestions where I can get one cheap now that I have a DVI card?
I got the OEM as well, my card came a little banged up, probably due to the lousy packaging job that newegg did. the metal bracket was bent (pliers fixed that) and one of the Falco inductors was broken and the small piece of plastic that was ratting around inside the static bag. but the card works just fine, so it's not all that big a deal. it's noisy as hell for about 3 seconds when you first turn the computer on or reboot. I use ATITool to control the fan speed, anything above 14% starts to get noisy.
14%? That seems like a pretty slow fan speed?
Originally posted by: Sonikku
How is it Anandtech could do a Video card price roundup this month without even mentioning this development with the PCIe X850XT?
Add me to the list. I was shocked to not see this in the listing.
Same.
Thanks! The manual says the card has a DVI-I connector. The monitor's manual says DVI Lingle Link. That page you listed has everything, so I should be able to figure it out.
Originally posted by: kalrith
I'm sick of not being able to game at all. My 7800GT RMA wound up being a refund rather than a replacement, and I've been using a 10-year-old PCI card that won't even play videos on MSN!
Originally posted by: OCedHrt
While I said I was too lazy to create a new thread, now Newegg has it starting at $160 AR. This is $10 more, you got that right, only $10 more than the X800GTO^2.
As far as I can tell, the card is the same card in all 3, just different package.
100106L RETAIL <- $154AR!
100106SR-RD RETAIL <- $164 AR! OOS.
100106-RD OEM <- Gone?
Are all these the same in terms of specification? I couldn't see the memory speed of the 100106L on newegg.
Thanks,
JJET
