Greetings
I have problem with QoS using 2 routers
Routers:
Router1: Asus RT-N16, SW: Tomato by Shibby (Tomato Firmware 1.28.0000 MIPSR2-102 K26 USB AIO), this router is set up as main router with DHCP enabled, PPPoE enabled, QoS setup
Local IP: 192.168.20.1, netmask: 255.255.255.0, gateway: 192.168.1.1 (modem)
Router2: Asus WL-500gP V2, SW: DD-WRT (DD-WRT v24-sp2 (08/07/10) mega - build 14896), set up as Wireless Access Point (I followed this instruction: http://www.dd-wrt.com/wiki/index.php/Wireless_Access_Point ) - DHCP disabled, WAN disabled
Local IP: 192.168.20.2, netmask 255.255.255.0, gateway: 192.168.20.1
Routers are connected with UTP in LAN port on both routers.
Problem: Devices connected to router2s WiFi are seen on router1s IP Traffic Details under IP 192.168.20.2 this IP belongs to router2 all other types of connections are working OK (router1 LAN and WiFi and router2 LAN) problem is only with router2 WiFi.
On router1 I have setup DHCP with static leases to all home devices and all of connected devices get correct static IP address, no matter how are they connecting router1 LAN or WiFi and router2 LAN or WiFi.
How can I setup router2, that router1 will see all devices on their static IP under IP Traffic Details? that I will be able to set QoS for each device different.
Thanks for your help.
Routers:
