Jeff7
Yes, a semi-technical question in OT, but there really weren't any other categories where it seemed to fit.
I'm working on a backup power supply for a wood pellet stove. Two final questions:
My Kill-A-Watt gives me this:
in 263 minutes, power usage was 0.40KW/H. So that's about 91.255W, correct?
I want it to run for 24 hours - about 2190 watt-hours.
So if I get two 12V, 105A lead acid batteries, stick them in series, that'll provide an absolute maximum of 2520 watt-hours, correct? Granted, this will be close to a full discharge, so it might not be too great for them, but these will not be getting constant use anyway - only when the power is out for a long time in the winter. Will a deep discharge really be that damaging? Or should I look for a slightly higher capacity battery?
And the last section is on the quality of the inverter. This is the kind of motor that the augers use. The motors are rated at 1RPM. The blowers (1 combustion, 1 convection) both use motors of similar construction, but they are of variable speeds.
Can these use a modified sine wave, or should they have a real sine wave inverter?
Second option
We've also got a gas generator. Someone I just talked to suggested a sound dampener for it. I might just invest the money for this project into that, and a larger gas tank for the generator. So this lovely battery backup project might die right here.
But even so, was my math at least correct? 😀
Edit#3: I'm now looking at these mufflers.
The decibel reductions don't seem to impressive though:
I wonder about a wooden enclosure with some kind of powerful ventilation. Two of them should do the job - adds about 70W to the power consumption. Only problem though would be weatherproofing the things, but I imagine that could be solved easily enough.
That, with some flame-retardant sound absorber lining it might actually do more than those little metal mufflers.
Thoughts on this?
Second option
Up to one-half the exhaust noise level of any other spark arrestor or compact muffler (2 - 4 dbA quieter). Optional Resonator available for additional 4 to 6 dbA reduction.
Thoughts on this?
