2 Questions, 1 Yes/no otherone is, well look and see
Cogman
Ok first question, Are there Splitter Cables for sharing one monitor. or to put it diffrently, You have 2 computers and you want to share one monitor. What I was thinking of is with a Switch that would change back and fourth between monitors. 2 Is there A probilem with the D-Link 120 and Talking between Winxp and ME? cause I XP on my computer, and ME on my moms (she wont let me upgrade it 🙁) and I cant Break Transfer Speeds of 10 kbps. I know it runs faster because I have another machine that has XP on it placed in the same place as the ME machine and it Transfers around 100-300 KBPS with the same USB card (This is a Wireless usb Network card). I already contacted the D-Link and they Just gave me the automated stuff. Here are my 3 systems
1. XP, 256 DDR Ram, Thunderbird 1.4ghz, Geforce2 MX 64, 40 gig Maxtor
2. ME, 64 SDRam, Celleron 700, IBM 2mg vid, HP built it, 20 gig FireBall(or something like that).
3. XP, 512 SDRam, Duron 600, Really old Vid, like 2mg Tyan or something like that, 3 gig (Really old IBM)
The Third was mainly Salvaged crap from an IBM comp I had earlier.
Tnx in Andvanced
Get a KVM switch, for example from Linksys. The set should go for $50-$70, including the cables you need.
That way you only need one keyboard, one mouse, one monitor, and if you press CTRL twice, you switch computers.
I love it.
the 10kbps sounds like a driver problem on the ME side.
Try and see if there is a newer, better driver.
hum. I have Tryed Updating the driver, and Uping the speed. When I upgrade the Driver it will not connect to the network. but ill try again.
